Discuss Calibration Date or Commissioning Date? in the Australia area at ElectriciansForums.net
acvc
Can anyone help me out here? I've just looked at the Calibration Cert for my multimeter. Although I purchased the meter last September (08), the calibration date is November 07. I first used the meter on a (non-part P) job in February this year, so I'm guessing that's what counts as the Commissioning date. First question is ........ does it need to be re-calibrated a year from the old Calibration Date or from the Commissioning Date? Second question .... where does it go to be re-calibrated and how long and how much?
Many thanks in advance.
If you are registered with NICEIC etc and they ask to see your current and previous certificate I think you will find that they dont care when it was first used. As for costs they vary from about £30 to £90 depending on what you have and where you go. Its best to google it and go to the closest to you. Something like megger calibration should do the trick
Chris
Yes have also used (on site calibration) have had no probs with the guy and as old dog says he comes to you, he can be found on flea bay:)
Hi,
I was told by an NICEIC inspector that as long as you keep an
accurate record of 'continuing accuracy' then there is no need to
calibrate your meter (ever) - as long as the readings don't drift, of course.
Save you some money that way:)
Cheers
Wayne
Hi sixfingers,
Yeh, the bloke I spoke to said it also depends on usage and how
you look after it eg. thrown in the back of the van etc. but he
did say that as long as the readings remained constant then that was fine.
If you send a meter for calibration that doesn't need it you're just paying
them £80 to perform the checks that you are already doing yourself.
Cheers
Wayne
Wayne My test equipments due in june when it 2 years will be up since last calibration,My niceic inspection will be around october so i will hold fire on calibration to see what he requires if all goes well ill save £60 :D
Regards
Sixfingers!
Hi,
Cheers
Wayne
hi wayne,
my nic assessor who is also an approved contractor told me it has been 6 years since he had his meters calibrated as his monthly test record has stayed constant. makes sense really ;)
Thanks very much guys for a good range of answers, really helpful. I've done two monthly checks on it and the readings are constant. I'm panicking because I've got my NIC (much delayed) first assessment coming up soon. I think I will have a look at the guy who does it on site anyway. Thanks again.
Have to say, i think the monthly check is a good idea but i would still get it properly calibrated at least every couple of years or so for peace of mind and for the records.
After all, the serial numbers are referenced on the certs.
Reply to Calibration Date or Commissioning Date? in the Australia area at ElectriciansForums.net
I really hope someone can help me. Last July I got an electricity bill showing an enormous rise in my kwh consumption of about 900% from what it...
Hello All and happy new year. Over the holiay I have changed all of my old sockets to some nice new ones and added a couple with usb sockets for...
A bit of a mini essay but these questions have been building up in my mind over the last weeks and months as I've been studying and volunteering...
Hi, Similar'ish question to my other thread but little more info now so a different approach but sorry if duplication. UK, single phase. Just had...
So I am a fully qualified spark with my own company, however I also have a few properties I rent out. One of my tenants asked if they can have an...
10K
