Just picked up 3 socket "mobile" Mains kit.
hi gear , with 16A isolator and 30 mA RCCB by Hgg .
It had the traditional at least 1 screw loose on Outgoing Neutral ferrule.
( finger tight )
Incoming cable is a bit frugal at 1.5mm sq( and GREEN ) .
Is anyone aware of other problem areas .
( It will be used for intermittent - light loads- a few days a year ) Camping .
--- Or I would have spent more --!
Blue plug 16A-6h -Moulded - No screws .
Is anyone aware of any reliability isues - if treated kindly . (un-wound!)
(Documentation supplied -advises -No unattended operation , get out clause )
( Splash proof but doesn't like rain . )
I would test the RCD to ensure it is correctly and safely operational before use.
Overall the unit sounds like it could be used reasonably indoors for a maximum of a 16A load.
No idea about the manufacturers but if the units are CE marked and state they comply with the appropriate British standards then you ought to be OK.
However the price does tend to err toward the low end of the market.
west midlands -- UK
Other
If other, please explain
Lapsed trainee ( was doing stage lighting 30yrs ago),
+ father of Trainee -who has recently jacked it in !
Camping bargain from China-RCD Electric Hookup ?
static zap,
static zap,
