As above , door switch, - test between plug and terminal block, block to on off switch ,on off switch to door switch - what make is it
it is hoover make. i have tried the obvious. i will do the tests you have suggested. thankyou.
Mine died on me a few weeks ago. Tested as above but it was a crimp connector that had fallen off due to vibrations. Check all connectors inside.
