J
jacksy
Hello all
I need some good qualified advice. I am lowering 4 ceilings in my daughters property. This is due to the cost of heating the place. The dropped ceilings will be approximately 3ft lower than the existing ceilings. Can I just add longer wire from the ceiling outlets to the new lowered ceilings? Or is it more complicated than that?
cheers all
Basically yes, but bear in mind you will be joining the longer cables to fixed points - how will you get at those fixed points/joints in the future if you need to? You will have to ensure that the connections are maintenance-free or future-accessible.
PJ
Wow that was quick fellas
1xlight in each room Kas1.
should I worry that much about possible future problems? How often is a problem likely to pop up? maintenance free connections?
Can anyone recommend another solution. These ceilings need to be lower, so I have to come up with a solution. I do not touch electrics, so will get an electrician in but just want to know my options before hand.
cheers for replies guys
ps any sparkies on this site based in Hull?
Id suggest maintenance free junction boxes
Ashley J803 Maintenance Free Junction Box 32A 3 Terminal
Them are the ones, just join the old cables in there, put your new cable in match the colours (Or if its old colours to new you want Red - Brown, Black - Blue and Green / Yellow - Green / Yellow..
Then id also suggest, putting the end wire into a light before lowering ceiling making sure they all work fine before you fix a new ceiling and then it not work as you never know who wired the property before and may have all polarity wrong!
EDIT!!
I just seen which JB i showed you, you want the 20A lighting one, should have 4 connections inside rather than 3.
ideaslly, you would remove the existing rose, extend the cable/s using wagos or similar enclosed in an enclosure, then refit the roses to the lowered ceiling. can't see it being a big job for a qualified electrician.
1 light in each room shouldn't take a decent spark much more than an hour or so to rewire to the new positions two hours tops
might entail 2 visits though. 1st to entend cables and call back to refit roses after new ceiling is installed. might be cheaper to buy the daughter a woolly jumper. :6:
That did make me laugh..jumpers already on most days.
- - - Updated - - -
EDIT!!
This sounds like even i could do it..really appreciate the help
Can you get above the ceilings? If you can then pull the cables out into loft, joint them there and poke the new cable down through.. That way if there are any issues you can still get to the connections :)
Talk her out of the job, don't cover up all that exiting coving from the 1800s she'll regret it in the future it's as bad as putting hardboard on all the panel doors lol
One guy i spoke to reckoned it was a big job, would entail lifting floorboards and mentioned that it would be in the hundreds :-/
my eyesight is poor and crawling around loft spaces trying to wire electrics is something i would like not like to do. Electricity is dangerous and is a pro job in my opinion. It does sound fairly simple though
