Discuss Candescent replacement lamp in the DIY Electrical Advice area at ElectriciansForums.net
We have dusk to dawn Hi-Lo PIR outside lights installed 14 years ago. They use incandescent lamps.
These lamps have now failed and of course new ones are no longer available. I've tried an e27 dimmable led lamp but that's not working. Are there any e27 led bulbs we can use? We could replace the whole unit but as we've got 7 around the house that would be an expensive option.
Any suggestions would be much appreciated.
Many thanks!
Never considered halogen.
Now ordered 18w from Toolstation, only £0.98.
I'll post how I'm getting on with this.
I'm not a lover of halogen and in the process of changing our halogen down lights to led but just 18w shouldn't be too un eco friendly.
Reactions: DPG
Halogen are lower wattage than the equivalent incandescent GLS lamps.
What were the original lamps wattage?
Reply to Candescent replacement lamp in the DIY Electrical Advice area at ElectriciansForums.net
Hi all. Slightly out of the ordinary, but I'm looking to replacing between 60 to 100 standard size E27 bulbs with LED equivalent. The catch is...
Can I use multiple GU10 led lamps with their own PIR sensors in the same room? I have a row of existing lamps 600mm apart in a straight line & I...
We have an LED recessed light that has failed. The unit is marked GLOBO 12363 (which I'm assuming to be a model number). But I can find no...
Hi we are replacing light fittings in our home. Im confident with the fitting aspect, but have run into doubt in making the right choice of...
I’ve got bad ballasts and am replacing the T12 fluorescent bulbs with Halco direct wire, double ended T8 LEDs. The fixture has 4Rapid start bulbs...
