does anybody know a quick way of inputting repeat data on the scedule of tests. e.g. if you've got 10 circuits, all with 60898 MCBs, can you enter the data quickly on all without having to type it in on each line?
I take it you mean 'schedule of circuit' details when you're mentioning 60898's?
If you're talking schedule of test results then the cursor must be in the circuit number column for the Ctrl and # trick to work, on the circuit details, the cursor can be anywhere on the line.
That's weird, I'm doing a PIR right now and copying using the Ctrl & # method, I wonder if it's a feature of the full package rather than the free version, which are you using?
sounds logical. one problem i'm having as well is that when trying to enter 60898, the pop-up gives me the choice of device as in MCB or fuse, but no BS nos.
