Discuss Certs in the Industrial Electricians' Talk area at ElectriciansForums.net
R
rapier
HI
My boss as recently finished 2nd fixing a property and he has put a 17th edition 7x7 board on.
Hes also put a 2.5mm swa into the garage under the ground in a soil pipe. He left the swa in the house my the cut out.
So he had his 25mm tails in the isolator and he took 2 10mm tails out with it into a 2 way ccu with rcd.
So he told me to go and test the whole installation as he doesnt do much testing
I have tested all the house today on the 7x7.
I am wondering where i put my results for the garage fuse board does this mean a new set of certs for this.
Hope i make sense.
I would be putting it on a seperate cert as it isnt fed from the main board. If you took the supply off an mcb in the 7x7 board, this would b classed as a dis-circuit. Hope this helps
The installation although having 2 dist boards both come from the same origin of the supply therefore are considered as one installation
The EIC should contain 2 sets of test resuts for each dist board contained in one EIC
Reply to Certs in the Industrial Electricians' Talk area at ElectriciansForums.net
Hi, just looking for advice. Ive been to look at a Fire alarm install job. While checking where i will take my supply from. 3 phase sub board, i...
Hi I have a customer who has a kiosk with 100 amp cut out fuse supplied from UK power, he needs to bring the power 178 meters to his house, He...
Was having a poke around the old man's house today. Anyway. DB is under stairs (18th ed following a recent extension. Not done by me but it's...
Hi all, I recently moved to an older property that had a run down garage. We had this removed and a summer house put up in its place. The old...
