Guest viewing is limited
Deleted member 105832
Hi,
Our kitchen has 6 ceiling lights all controlled by any of three switches.
One of the lights is above our breakfast bar and I want to change a nearby switch to control just that light only while leaving the other two switches still switching all six lights.
Is this a simple re-wiring job?
Thanks.
Hi,
Thanks.
No not a simple job, maybe for an Electrician, but a DIYer a nightmare would ensue.
Lots of building fabric would be damaged walls, bedroom floors and ceiling maybe, depending on how it was / is wired.
If you Know what you are doing its quite straightforward and could involve a bit of mess depending on what your walls are made of. The fact you ask suggests you'd be better off from a safety perspective and time one of getting a local electrician in to do it.
Thanks for the replies, I'll either leave it or speak to my local electrician.
Thanks again.
Change to 3 way lighting.
DIY Electrical Advice
Thread Tags
Deleted member 105832,
