Hi guys/gals
Directing this question at you that have transitioned already from sparky to pv insatller. I have my first pv install after getting so many queries since the energy price rise and looking to get one under my belt. I want to go in properly and that it is being installed to a high standard. It is a 2.72kw system on roof (garage) system. 8 panels.
Getting a local roofer to do the construction on the roof/set up/ and get cabling safely into attic space. (Do the hook sit on top of tiles or would the tiles need stripping back and cutting around the hooks?
Reading up i belive g98 applies to this install so i can notify dno up to 28 Days after install?
The inverter will go on the block wall next to the consumer unit which has spare rcd ways and into an ac isolator. Also putting a generation kwh inbetween here.
Going to be installing an iboost in the house at the same time on the immersion tank.
Any other tips would be greatfully received
BS
BS
