Discuss Cold Storage High Bay Lighting in the Electricians' Talk | All Countries area at ElectriciansForums.net
I think that high intensity discharge lamps(HID) or metal halide are good options for cold storage its maintenance cost is also low and it gives bright and clear light.
Thanks!
Hi I am newcomer to this Forum,
Has anyone used LED lighting in cold storage warehouses? The light will be switched off at night so I wonder if problems will arise due to condensation?
John
You'll always have problems with condensation.
Whether it'll affect the LEDs I don't know.
The main problem I find with LEDs, is that they don't radiate in all directions.
Great as spots, but not much good for anything else.
Reply to Cold Storage High Bay Lighting in the Electricians' Talk | All Countries area at ElectriciansForums.net
Hi all, any advice would be greatly appreciated. Went to do some work at a factory unit on Monday ( changed 20 florries to LED battens and changed...
Hi all, I have an Economy 7 storage heater Dimplex CXL24N - 3.4kW Storage Heater + Convector ( there not available anymore) that dos'nt work and...
I am asking on behalf of a friend who has an outbuilding that he uses as an art studio, the building is fully insulated and is currently heated by...
Hi, So I'm trying to understand what's going on with my off-peak electricity supply, as something's wrong with it and I'm trying to determine if...
Hi brains trust, I am aware of typical wiring and legalities hence the questions. Looking for a wiring diagram to allow me to use a dual switch...
