Search the forum,
Discuss Colours Of Conductors. in the UK Electrical Forum area at ElectriciansForums.net
7029 dave
Mentor
Just looked at a thread, got me thinking of old imperial cables etc. The mention of the old red white and blue 3 core pvc no cpc got me thinking about a situation. I remember because have only seen it once in 37 years on domestic installations.
Block of flats in East finchley North London,Local authority full conduit system, on the lighting circuit all live conductors were white . Anybody else ever seen this in their time.?
It was acceptable to wire single phase circuits to the phase colour, eg red, yellow or blue on larger installations but only time I have seen it on domestic was when an Octoflex modular wiring system was used where all the returns from the lighting switches were yellow.
Any idea which regulations that was?
Can't check at moment but look in 15th Ed under conductor identification sure there is some reference it can be used on larger installations, see it alot on 80s installations tested a school this week where single phase circuits were wired red, yellow and blue.
Ok, unfortunately that's one of the ones I don't have yet.
I've only got 1st, 6th, 9th, excerpts of the 12th, 13th, 14th, 16th and 17th so far.
One day I will have a complete set!
15th edn, Table 52A, Colour identification of cores of non-flexible cables ... for fixed wiring
Phase of a.c. single-phase circuit: red (or yellow or blue*)
*As alternatives to the use of red, if desired, in large installations, on the supply side of the final distribution board.
I have just had chance to look at the 15th Ed and Table 52A and it seems it was acceptable on the supply side of the dist bd and maybe not outgoing ways (see preceding post). Unless other versions are different seems a lot of specifiers misread that.
I actually remember wiring circuits in the mid to late 80's using the phase colour along with a black neutral. Don't know if it complied to the regs though but it was specified.
Why did we ditch red for Brown?
WE ditched Red and Black in flex for Brown / Blue around 1970 as part of European harmonisation, around the same time we were also going Metric in measurements.
Brown phase colour was more common than Red in Europe so we lost.
Hi all,
In 1987 I came out of my time and started running a section of a school rewire. We wired all SPN circuits from TPN DB's in phase colour & black. Half way through the consultant visited site, and we had to rip out all the yellow / blue wiring and rewire in red & black only.
It was far easier to trace circuits in trunking the old way IMHO.
Also, one of our buildings, built in 1936, still clearly has R W B marked up in the busbar chambers as phase colours.
Cheers
CW
Actually it was never permitted for final circuits - only for distribution circuits (submains).
Doing an industrial EICR and found a socket in a conduit system with the live ring conductors blue and yellow...with a red spurred. Can't see the problem though, I knew what they were without having to think about it and it tested fine.
I can see a problem. What is a circuit wired with blue and black live conductors? Is it L3 and neutral or L2 and neutral with either swapping between phase and neutral?
It is however permitted by ETCI Wiring Rules in the south of Ireland.
The neutrals are 3 blacks. The lives R,Y,B.
It's an old installation, all wired in old colours and not a chance of any alteration, and if someone can't get their head round the situation they are either thick as pig s*** or from across the sea...in Europe somewhere..
Use a Reg for a situation.....after weighing it up.
But Risteard has a point there, that a blue/black circuit has become ambiguous since harmonisation. In a 3-phase circuit, you can tell which version of colours applies, so you can identify which of blue or black is neutral. But in a single-phase circuit with blue and black only, the absence of the other phases makes it impossible to know with certainty.
I like the setup in France, where line conductors can be any permissible colour other than blue or G/Y, which makes lighting wiring much more obvious. For example, brown for supply, red for S/L, a pair of oranges or purples are popular for strappers. You can 2nd-fix a 2g 2-way switch on a conduit system and know the functions of all the conductors more or less straight off.
Yes, of course he has a point, but it depends on the situation and the possibility of problems occurring.
typical yorkshire, save a shilling whenever. you'd need to sleeve the red with brown and the black with blue. sod tape. it falls off in time.
Black singles with a grey sheath.3 core and earth contains a black core.
I get you now, never seen it referred to as d/s before.
I still don't see how 3core relates to this? The black in 3core denotes core number 2, the singles by definition do not have a core number 2 therefore a comparison is not possible.
I see no issue with sleeving it with whatever colour you need.
Interesting history of technical materials here.
Early US wiring was bare. To reduce death it was 100V. Soon delivered as +100V/0/-100V to give twice the power without twice the copper. The "0" was nominally tied to dirt.
Rubber insulation came a little later. (Metals and wires were more mature than rubber production.) The rubber was heavily cut with lampblack for toughness and economy. All Wires Were BLACK.
Interestingly as late as 1915 some argued that an UN-grounded system is safer. Easy to show in a lab. But in the wild there are no un-grounded systems. There is always some leakage, not enough to notice at the generator, but ample to kill a grounded person on the other leg. (Also longer lines with more lightning exposure fared very much better if frequently tied to dirt.)
That balderdash was cleared up. A groundED entrance conductor was first allowed and then required. And the inside wiring had to have that leg of the line "Identified". Since all rubber was black, the rubber was painted. Probably zinc-oxide, oil, and benzene to "bite" the rubber. Didn't cover or stick so well. Now we had the black "hot" wires and "Identified" (groundED) wires with bits of white/grey flaking off.
So:
Black = Hot
White(?) = groundED ("Neutral")
Sadly this crap paint continued long into the 1940s. Both my parents and I owned houses where the Identified wires were far from White and often pretty darn black. Sometimes we had to fall-back on the old plan: All Wires Are Black.
This is also sad because durable White Rubber was available in automobile tyre side-walls.
Like car rubber, electrical rubber breaks-down over the decades. My parents were lucky to sell-out before their rotting wired burned the place down.
PVC and similar plastics made the difference. Any color is pennies per mile cost, so all primary colors became available, and have usually proved durable inside conduit or cable.
FWIW, "Green" (groundING) conductors were rare here until the 1970s, though for a long time we pretended that metal armored flex was an OK Ground.
BTW: I have seen lots of gear where all the internal wiring was white. Utter madness to trace and debug.
Reply to Colours Of Conductors. in the UK Electrical Forum area at ElectriciansForums.net
Wouldn't normally note this as an observation on a report but feel I need to. The way the building has been wired is all circuits on L1 have been...
I've fitted some led lights with power supply and mi light controller, they were working fine and all colours could be seen, then for some reason...
Getting desperate to clear my small garage, and I have a bit of old red/black T&E. I used a few bits to add a socket or two in my flat and a...
Quick Question. BS7671 specifies colour coding for 230V AC conductors, but I've looked through it and I'm sure I can't see anything which...
