Discuss comments please in the UK Electrical Forum area at ElectriciansForums.net
J
joesdad
I have a proposed design for office power which involves a 32 A single phase ring circuit running in singles in sub floor trunking via a flexible conduit directly to a rotosoc type desk socket connector to be fixed under a group of desks. The connector is branded as being manufactured to BS5733. is this installation compliant ?
It probably depends on what's going to be on each desk - is it just a computer terminal and LED monitor and nothing else, or can other things be plugged in as well?
As darkwood suggests I'd break it up a bit.
Due to potential high earth leakage current in an office environment,it would be advisable to run this ring in 4mm and remember to terminate the earths in different terminals in the sockets and at the board...2 radials would be even better.
NO WHERE NEAR ENOUGH INFORMATION, LENGTH OF RUN?, LOAD?, the actual design sounds fine, having a metal clad box under a floor with a flexible pipe to the desk sockets pretty normal, but more info required regarding whether one ring will suffice.
if you've already proposed this design to the client , then its probably a bit late in the day to get 2nd opinions............
:-D
Reply to comments please in the UK Electrical Forum area at ElectriciansForums.net
Experienced Electrician, C&G 236 Parts 1 & 2, AM 1 & 2 18th Edition Am 2. (JIB Gold Card) I've been out of the trade for some time, but did a...
  • Locked
5K
Ferrets are known for being small, resourceful, and incredibly clever. They can solve many problems by fitting into tight spaces and doing jobs us...
So that I can understand how the electrical energy that I consume is being used I want to fit one of these to my consumer unit (CU) -...
6K
