robd
Hi all,
Can anyone recommend a commercial downlight please? I'm doing a small shop fit and need 6 dimmable downlights for a fairly dark room. Usually I'm a KSR man as I've found the reliability of their stuff excellent. However got a price and they were roughly £100 per fitting largely because of the dimmable driver. I need them to be brighter than a standard GU10 but I've not fitted anything like this for a while and wondered if anyone could recommend anything.
Many thanks,
Rob
I buy BELL lamps at 540 lumens - they are GU10 and are available as dimmable.
Lamps - about £3 each, JCC fittings about £7 (fire rated), when you add a Varilight pro LED dimmer at £18 it is all affordable
I refuse to install fittings with integrated lamps.
Thanks I've found some Collingwood ones at 1300 lumens which I think is more the level of brightness required, dimmable at about £25 a fitting we'll see how they go, so long as they go in and out easily they should last for a few years and be easy enough to change when they fail. Couldn't find a changeable lamp with a high enough output aside from that I agree about integrated fittings but sometimes you don't have a choice. Thanks for replies
1300 lumens is about double the aveage downlight. will be bright.
Yeah it's going on a dimmer will be interesting to see what they are like the room is a real dark hole at the moment admittedly hasn't been painted but there is talk of possibly needing to film in there so wanted brightness, it's a sports fitting room.
does it have a grid and tile false ceiling?
you can get 600 x 600 panels with metal surface mount patresses . fitted loads in an estate agent's.you fit the back box, then slide the fitting in.
Have already wired it for spots but after I did it I thought about putting brighter ones in but those frames do look good I've used similar before but they were a bit fiddly to assemble
