Relocating away from the external influences not an option? Any chance of a wider shotAny recommendations for a commercial kitchen single phase DB?
Small pub kitchen and no space, two fryers in the same room and lots of lovely greasy pub food being knocked up so I'm looking for a DB or options that offer some grease/fat resistance.
Or a standard DB in an enclosure?
Two hopes, make that three, Bob, None and envel...Relocating away from the external influences not an option? Any chance of a wider shot
That's definitely an option. Three of the ways on the original board are for lighting, all three lights. A couple of socket circuits, cooker and a fan. I can do away with the cooker and fan circuits as there's a TPN board in the next room running those.I have fitted a few of these in external enclosures however its rating is lost if the plastic lift up cover is not snapped shut which you can guarantee will happen if something trips.
Just strongly advise it be moved otherwise it'll fail in use due to the external influence, move it once pay once, don't move them pay again in short order when it gets full of grime and rubbish.Two hopes, make that three, Bob, None and envel...
Usual landlord prices...
Landlords have short term views. You can only push so much.Just strongly advise it be moved otherwise it'll fail in use due to the external influence, move it once pay once, don't move them pay again in short order when it gets full of grime and rubbish.
I did look at extending to the TPN board and using that but the only cable route is rammed with circuits for the oven and fryers etc. This board only does sockets and lighting so potentially I can cut it right down.
