Discuss Competent person scheme in the UK Electrical Forum area at ElectriciansForums.net
New to the thread, i imagine this question has been asked before.
I want to ask in my way though, with the hope of some advice, any would be appreciated!
I've got my level 2 & 3 2330 done in 2009 (still acceptable)
Recently done my 18th edition and 2391-52
Cant do board change or new circuit as its notifiable to building control but need these for the scheme.
Building control have given a completion notice for a board change but now want to charge around £300 (quoted) for this per notifiable job.
Any suggestions from anyone who's been down this route how I can build my work for the competent persons scheme?
Cheers
It's worth speaking to the schemes.
In my experience (and others that I've seen posting about this), they are fairly flexible on the initial install(s), where you can do the work for the assessment, hopefully pass, and then immediately notify it with your new found recognition...
The NICEIC took that approach with me, though it was 10+ years ago.
In theory you have 28 days (I think) to notify after completing the work - although in practise there seems to be no 'comeback' for notifying later...
Yes, doing the actual work between applying for the scheme and your assessment date is the usual approach. NAPIT were the same.
If I read your post correctly it sounds as though the job has already happened and BC unfortunately already know about it. If not ignore the rest!
The only possible problem in this case is that unusually BC know about the job and could beat the drum a bit for the notification (or their £300 to do it)
I wouldn't delay getting the CPS application in anyway, and this can still be used as an example job for an initial assessment. You could have a race and see whether NICEIC or NAPIT phone you back first! You only part with cash when they call you back, and NAPIT do interest free payment over 6 months.
If the building inspector for the job is approachable, and you can show that you are in process of joining a CPS you might be able to agree some flexibility with the timeline. Some are very reasonable!
The 28-day clock only starts ticking when the work is completed, and even if the board change is done, there could be some other aspect of the job that perhaps only gets finished shortly before the CPS assessment. . . .
Ive known some jobs run 12-18 months before they eventually get notified via the cps
no point doing multiple notifications for the same property , might as well wait until its 100% finished before signing it off / notifying
Reply to Competent person scheme in the UK Electrical Forum area at ElectriciansForums.net
Evening all, Just a quick question, I am an electrical maintenance engineer and have 18th edition, inspection and testing and so on, so I get...
Completed my AM2s start of this year. My whole career plan is to run my own company/sole trader. Be my own boss basically. I always get asked...
Hi, I would like to do some minor domestic electrical work while I am completing my NVQ level 2 in electrical installations. I have the 18th...
5K
NICEIC Certification Scheme Getting accredited to
Looking for some advice regarding joining a CPS. I've been in the electrical industry in various roles for nearly 10 years. I started my...
