K
Knobhead
Only ever had the chance to use it on one job. Six sub boards in an office block. After being used to nothing but SWA I fell in love with the stuff, so easy to work with.
Are you suggesting that the insulation on the neutral conductor is not satisfactory?
If you have any pride in your work then it needn't look a “pigs ear”. I could take exception to your comment, but I won’t.
How do you terminate these split concentric sub-main cables??
Like every wiring system, there are applications where specific cables can be used. I see no reason why split concentric cable cannot be used by non-DNO for sub mains installations. It is never suggested that it is an armoured cable and should not be treated as such.
I personally use it for the majority of domestic sub-main installations, where appropriate. The reason I do is because I find it much more flexible and therfore easier to work with than SWA.
you can do a decent job with some small tie wraps, a lot of the new build housing i was working on was done with it for the sub mains.
Honestly, ...tie wraps?? lol!! Oh Dear!!!!
Yup. Nout wrong with little tie wraps :|
