i had a look at this page 4,a stick on angle thingy...dont waste your money kids,if you want 90 deg bends for free,just bend some pipe around 90,take it out the bender and measure against the wall so its true,put it back in the bender,bring the bending arm back to rest,then use a marker pen and mark the former where the arms rests,then just bend to the line and theres your 90,do the same for any angle you need,mark the former on the other side if your bending up,a bit of practice later you wont even need the line,and if you need to cut straight,keep your hack saw sharp and level to the pipe,
