Hi, got a job to connect up some new spotlights in a conservatory. Roof has been replaced and plaster boarded. I'm assuming insulation has also be installed.
Originally the client purchased Enlite Spryte non-fire rated IP44 LED downlights, however I thought that they should be fire rated as they are being recessed into the ceiling, so after a bit of research I found an equivalent model by Lap (CosmoEco - link below). Have been told space is restricted so these were the shallowest ones I could find.
https://www.screwfix.com/p/lap-cosm...0v/6570x#product_additional_details_container
These are fire rated but only have an IP rating of IP20. Would this be suitable in a conservatory? Obviously it isn't a bathroom so usually this IP rating wouldn't usually be an issue I would assume, but as its a conservatory roof could that be a problem?
To be honest, I just assumed they would for safety purposes due to insulation in ceiling and to stop the spread of a fire should it occur. It would of been my inclination to purchase fire rated downlights if I'd designed the job.
If its not a requirement then the original downlights they purchased should be fine, however also interested to know if there would be any issues with IP20 lights in a conservatory?
It is worrying that you don't know this information to begin with but are still going ahead with the job. Also LAP is probably the worst readily available brand on the market currently
Very helpful mate, thanks.
At the end of the day I'm fitting fire rated downlights which I think is sensible and gives me peace of mind.
Fitted LAP before and never had a problem. I acknowledge there's better brands available but it is what it is.
Essex
Conservatory lighting
dannyG85,
Jjc,
