Hi all, had a blocked pump that caused a overload on motor, ocpd went before motor overload. Should the motor overload always discriminate with ocpd and operate first?
The motor overload was set to auto but I don't think it ever operated under fault. Motor draws 6amps under load and the motor overload is set to 7amps, prob should go to 6.5amps but 7 is lowest available.
Tried the manual trip and it works fine, so dont think it's faulty. Think it comes down to time current graph difference, not sure,any advice greatly appreciated.
