Discuss cooker elements in the Australia area at ElectriciansForums.net
A
anne83
ive got a double oven and the elements have gone in both ovens can i replace the element on one oven and use this without it tripping the electric or will i have to replace the other one aswell even tho its not being used ??
thanks :seeya:
You can replace the elements individually. Best bet is to type the make and model number on ebay, I find they are normally cheaper to buy on there than your local appliance spares shop.
If one oven is not used, no need to change that element. As long as it is not turned on, it will not trip the mcb
If you just want to replace one element then remove the other faulty one at the same time and make the wiring safe. If you leave one faulty element in place it might still cause tripping problems.
Reply to cooker elements in the Australia area at ElectriciansForums.net
Hi All, Seeking some thoughts on my own Omega free standing 900mm oven. Over the past year the oven has been tripping the supplying RCBO unit. I...
Hi all, There's 2 single fan ovens in the house my mother recently moved into. Posh elecronic AEG units. It's been sat empty for a year, so the...
Hi all, I'm about to replace our kitchen and one of the upgrades is to install two full size ovens to replace the original twin over under...
I have an electric oven - now many years old. I have replaced the main circular 2.5kW oven element (ELEHY6708) several times over the years...
Hi, To give a bit of background, it is a Lincat ESLR9 electric cooker. It is very simple design with two fans and two elements. Two weeks ago...
