fcu's in wall above units.led low voltage strip lights.
- - - Updated - - -
So there is a spur on the left above the units bud? is it fixed to the wall? if so what else is on that circuit, you may well be able to connect another FCU from it for the Extract fan, assumming its just the usual small fan with 2-3 speeds and a light combined, check the load of the circuit supplying those lights first, I reckon thats a good bet Fella, worth investigating.
i like your idea, it was a while ago i put in fcu's and can't remember how i wired them.
will have to investigate more, but can't foresee a problem.
well done!
