need more info on what you want. if you are just referring to an electrical installation, the cost of the certificate should have been included in the cost of the job.
this is a job that the plasterer that lives there has done himself but wants a cert for it but i have said to him that we will test it then if it is installed satisfactory then he will receive his cert i haven't viewed the property as yet but was wondering a ball park figure my colleague has quoted me £50 on a 1 bed flat size test and don't imagine his extension is much bigger than that
but am looking to view the extension before giving a figure
Are you refering to issuing a Part P Building Regulations Compliance Certificate, often refered to as Self Certification?
Or are you refering to carrying out a PIR?
bear in mind that if you are giong to issue an EIC (a frowned on practice), you are stating that it is your job and you are responsible for any faults that you may not find on testing. can you be sure all cables are installed correctly in prescribed zones etc.etc.?.
and £50 is nowhere enough to do a thorough inspection and test.
Quite right
But the qualifying supervisor system that is used in Domestic installation ( :83:Q.S) means that the only difference with the proposal and conformity is that, the plasterer is not employed by the certificate maker
If he was employed by the certificate maker,does the situation make this registration nonesense any more sensible ?
He would still be possibly untrained installing a possible crap installation,thats the problem with our joke system as it stands,so maybe bending the rules of that system isn't the right thing to do,but understandable
If you certify this work as your own and it and subsequently causes a fire or injury to someone, for whatever reason, it's your insurance and conscience at stake.
I'm not sure you're aware of that but if you are then it's up to you.
