Discuss cost to replace an immerser element in the UK Electrical Forum area at ElectriciansForums.net
have been asked to quote to replace an element. ive done a few back a while back and i dont want to short change myself. probably fit an 11in screwfix 17 pounds odd. lower element with good access, drain tank maybe 20min or so. travel 30min there and 30min back. many thanks.
You Arrive.
Locate isolation valve for cylinder and shut off.
Locate drain valve for cylinder.
A; find there isn't one and the only way to drain it is to disconnect the hot at the top and syphon the water out.
B; find it's at the back and barely accessible.
C; find it was easilly accessible but you didn't replace the washer in it when the cylinder was empty and when the water was turned back on it dripped and you had to drain again.
Start draining the water and begin to think it's taking a long time.
It's then you realise the isolation valve isn't fully shutting off, so you tighten some more and it shears closed.
Now the cylinder is empty you start to undo the heater but it's stuck firm.
You pull on the spanner harder and the boss rips out the side of the cylinder.
It's at this point you realise you should have done what EVERY plumber would have done at the time of quoting and warn that;
Even though the cylinder looks new there's a risk the heater won't unscrew or the boss may rip out.
Or because the cylinder looks old, there's a risk the boss may rip out or the cylinder fail somewhere else.
You leave at the end of a very long day with your £90 having had to pay a plumber up £500 out your own pocket to come and fit a new cylinder and immersion heater and or new isolation valve.
At least you can get your £17 back from Screwfix for a low quality immersion heater.
The nightmare scenario described by snowhead is the one to consider because its likely much much more possible than the element paradise I will describe below
Prefab houses
Open up the ply board that covers the hidden water tank (mother earth below)
Man No 1 removes the element,man No 2 catches the water in a bucket,that is until No 1 screws the new one in (10 minutes start to finish)
Believe me there will always a full bucket of water because man No1 will deliberately wait until the bucket is almost full before screwing the new one in:)
My brother just had a plumber out to change the top element on his dual element immersion tank.
£127+vat labour / £27+ vat for the element
Reply to cost to replace an immerser element in the UK Electrical Forum area at ElectriciansForums.net
Hi all, Im new to the forum and wanted to check something and maybe get some advice confirmation. Ive got halogen wall lights which use a...
HI Folks. This is my first post so apologies if it's in the wrong location. I recently installed a 3kw Solar system with an iboost diverter...
5K
This might be long so feel free to grab a brew. So, as some of you may know, i'm a 34 year old who has been dying to get into the industry. I...
9K
Hopefully someone wiser than me can help explain some odd measurements I’ve taken at my own home. This is a long read, I’ve tried to give as much...
4K
