davidcaulfield
How many sockets and light do people actually test on a consumer unit change? If I test all of them it would take me all day
Every item, always been taught every item, only do percentage selection if appropriate on ECIR even then most domestic 100% i always do
i always allow a day mate, do as many tests as possible , remove board, fit new board do final tests job done. When doing a board change a full EIC is filled in and every test at every point carried out. (people will correct me if wrong) You are responsbile for that installation then, whereas with a ECIR you are only testing to find the condition of the system and in that case only make note of what you actually test ie no testing etc of lights high up due to access
David - you don't half ask a lot of questions lol.
As gazza, when doing a CU change a day is always allocated.
However, i don't do 100% on a CU change. I do 50% and if i've found anything dodgy then i go the full works. 20% on an EICR then up it if you find out dodgy for me, but a CU change which warrants an EIC then i always do 50% and if i found anything dodgy i up it to 100%.
Although if when i find dodgy test results - possible interconnections on the ring ect... i'll always do 100%. Depends on the quality of installation and age of it as to how much i do really.
When testing a house, you should link the rings at the CU and go round to each AND every socket to test the continuity and polarity - failing to do so is NOT a good idea.
As for lights you need to do the same.
And yes a complicated board chage can take over a day, plus the tails and bonding.
What you should do, is visit the site the day before, draw a sketch of the layout, mark all the points and then work out which fuses control what. If you don't do this you won't know what to test - which will render your EIC worthless.
EDIT: And if you don't know where all the sockets are how will you be able to unplug everything, so that you don't blow up have their kit when you shove 500V down it??????????
