Spudnik
Well, what should have been an easy CU swap turned into a ****ing nightmare.
Did a couple of quick tests a few weeks ago before quoting.
Installation barely 15 years old.
Low IR between N/E bars.
Not to worry, well within minimums... probably a dodgy light some where, trapped cable in a socket...easy fix, usual stuff..
How wrong was I!!?!?!?!?!?!
Somewhere there is a N/e fault on the upstairs lighting, kitchen RFC and One half of house RFC.
Bugger.
Ran out of time, so thought, well, i got a couple of spare unprotected ways, ill swap the lights and kitchen RFC to those, and resume in the morning.
Did that, plugged the appliances back in in the kitchen, and it took out the RCD it WAS connected to?!!? WTF??
SO, another day of ----ing about trying to find some bolloxed connection some diyer has had a go at sometime in the past.:mad:
Let that be a lesson kids.... dont always assume!!!!!
Especially on a goddam CU change!
Sounds like a jaffa......Have you checked out the 'CU changes and you' thread......some good info in there.;););):eek::D:D
Days like this I bet you wish you took up something easy like Quantum Physics.................still could have been worse could have been me;)
bl00dy diy`ers :) well my day was not too bad just a late one :) 2:45am just got in and im nackered. been down near london to drop three strippers off. don`t ask :D easier than fault finding though
Long way to go just to drop off a few wallpaper steamers? B&Q sell them for twenty quid each! ;););)
Bugger.
Have you tried turning it off and back on again??? Lol
Well, as i talk to the client about what work he had done, he tells me the conservatory was wired by " a so called electrician."
How many times have i heard that???
Well, here is the result...
70mm plate screw pushed the neutral back to the box.
And, because the screw was too long, it striped the threads so i had to cut it off and remove the remains with my trusty pliers.
If i ever find him, ill gladly make him a bit lighter in body weight...
Other faults i didnt get a snap of, but basically, a bathroom light that the cpc had no sleeving and was shorting to N, and the kitchen sockets.... well, i dont know.
I pulled off the first socket to start testing again and it was all clear. Examined the cable with no obvious damage etc etc.
Never found the cause of the RCD tripping intermittently. Holds in a treat now.
Alls well that ends well.
Jobs a goodun.
what a star.... not.
i once did a rewire with someone who liked to nip the neutrals caused me more work than needed :mad:
