do any of you plaster your own chases back in? i do the odd small bit if its only one or two but i generally have a good lad do it and he's so much quicker and better than i am, its only cos the guy that is doing this house up has his own guy that plasters that this has become an issue anyway
i may well slip in the fact that the guy i use for plastering never has a problem with my chases, here's his number
I have used that line a couple of times, once for a kitchen fitter, and once for a plumber. Both times it had the desired effect.
i do my own if i can get away with it or know a guy, is he re skimming all the walls or trying to match up to existing? i always hate guessing depth of back boxes especially if walls need rendering as well.
He's skimming the whole house, i've left back boxes 2-3mm proud so hopefuly that should be about right
He has probably given your customer a silly price to patch up the chases and is trying to justify his costs by acting very professional like and making you look a fool to distract attention away from his costs, I like imago's comment about suggesting another plasterer, that will shut him up, nothing but a semiskilled bricklayers mate anyhow I suspect.
Well its been sorted, i went there this morning plasterer wasn't there but customer was, i offered the number of my plasterer but he wanted his guy to do it cos he does a "good job" so he got the plasterer on the phone and he admitted that he didn't like to plaster over pvc capping, the easiest thing to do then was to rip all the capping off and just clip the cables in the chase, a pain in the arse but happy customer, happy plasterer and sort of happy monkey, even though i don't like clipping like that but the plasterer assured me he's very careful around clipped cables, problem solved! I may start using oval conduit in chases, capping is a pain in the arse anyway
plasterer probably doesn't like capping because he's not got the intelligence to apply pva before skimming. anyway, as long as you got a result. then OK.
I plaster my own chases, But I can plaster, render, bricklay, hang doors, fit kitchens, fit bathrooms........
