DurhamSparky
Rocker and all other Di Log Users!!
any body had problems testing RCD with the Plug in Socket adapter!!
picture this! go to one socket and Press Test "Auto" it goes through motions and get results!
i go to the other side of the board and choose the cooker socket to plug in to and i get 50V signal in my screen!! ???? i go manual settings and select 0 degrees get 50V so i set 180 Degrees and get a good mS Trip time!!...! i then remove all my leads and put the probes on and test RCD with probes inserted to socket and it works fine!!
i then try again at different point and it works ok with socket adapter!! EHH!!!
wtf is going on! is my plug adapter going bad or is my meter goosed or is there some underlying fault on the circuit!
hahahaha! i really need the excuse to buy the 1552/3 (prbably teh 1552) as i dont really need the blue tooth feature!
Mate what you want to do is before you reset the RCD, switch the MCB for the circuit off, then reset RCD, then reset MCB, I've had this problem quite a few times and this normally solves it.
DurhamSparky,
rocker,
