I,ve done loads of bits for old people without charging,a common one used to be on the old wylex boards when fuses went,what I used to do was collect the mcb,s from wylex boards that had been replaced and fit them for the old people,that way they can just reset a breaker rather than rewire a fuse,I like to think that when I get old someone will help me when I get stuck.
i've done the same a few times. elderly customers, just ask for a tenner or so to drip some diesel in the van.
Interesting responses. Thanks Guys.
The problem is, I get at least 5 of these calls a week. My number seems be on some advice organisation's list of contractors they recommend to the elderly and infirm.
I can't run a business and earn a living working for what works out to be a whole day every week for just tea and biscuits.
So should I turn the work down?
Pass it on to someone else?
Find out which organisation(s) is/are recommending me and ask them not to?
I suspect I'm on the lists because I always respond, I have always managed to sort out or patch up the fault, I don't walk away leaving them without power saying "you need a rewire". I can only do this because it pays me to.
If it's got to be charity work then I could do one or two a week, if I have a quiet day, but I can't afford to turn down paid work to do freebies.
So given that there are at least 10 people above who would be happy to work for free, perhaps a few of them would like to add their number to the list?
in that case, i would find out the org. responsible and politely suggest that you are happy to do these call-outs at a discount from your usual rate, but you can't work for nowt.
