Discuss Diode CL04-12 110v 60HZ inverter in the DIY Electrical Advice area at ElectriciansForums.net
This is for DIY connecting a 110v 60HZ solard inverter from 12v DC battery to 110v AC 60HZ output. Using a CL04-12 Microwave diode that I already own. I want to know if this diode is right for this.
I want to protect my inverter while I use the electric power from electrical power Co.
And what end of the diode is open. Also if I understand right one end of it goes to ground. Sorry for the info I'm french doing my best.
Thank you very much.
If your idea is that you will prevent grid supply from being "back fed" into the inverter by using this diode.
NO, DO NOT TRY IT.
you either need to buy an inverter that is designed to be "grid tied" or have a suitable changeover switch between the 2 supplies (grid and inverter) and the load you are powering.
This is not a DIY job.
NO, DO NOT TRY IT.
Thanks James for the quick reply it's really appreciated.
What is a (suitable changeover switch between the 2 supplies)
Mean where do I get a changeover switch??
something like this
however the current rating needs to be at least whatever the grid supply is.
i.e. if the grid supply is fused at 100A then a 100A changeover will be required.
Again, this is not a DIY job.
mess this up and people get hurt by electric shock, exploding inverters or fires.
Thanks again is a rotary switch 2 position is the same as changeover switch??
No, they are not the same.
you really need to involve a local electrician in this.
I cant stress enough just how much of a bang it could make if you get this wrong.
Reply to Diode CL04-12 110v 60HZ inverter in the DIY Electrical Advice area at ElectriciansForums.net
Hello, So I purchased a Novopal 2000w/4000w(Peak) Pure Sine Wave Inverter DC 12V to 110V/120V. I purchased this so I can hook it up directly to...
So I'm looking to connect my car's battery directly to a Pure Sine Wave 2000w power inverter So I can use it on job sites etc to power a microwave...
Hello - hope someone can advise please. I have a recently purchased second hand Myford lathe which has a 3-phase inverter (Siemens Micromaster...
Hi everyone, I have a basic knowledge of electric but would like advice before I attempt, I have a electrical item that is powered by Voltage...
I used 12v dc from a 13 plate car battery to power a 12v dianamo dc motor and brought in an alternator to change the battery using the rotation of...
