Discuss Distribution in the UK Electrical Forum area at ElectriciansForums.net
Hi guys, just wondering if anyone has an alternative way of fusing sub mains other than fitting an MCCB panel? Basically I have a sub main to a laundry block, and one to a toilet block. There may be a db fitted next to the proposed panel in the future so I need to leave allowance.
I can’t think of any other way than MCCBs or separate switch fuses with a single point main isolator switch which will look awful.
Your options are a panelboard, busbar and switchfuses or distribution fuseboard as far as I know.
Unless you get a custom built bit of switchgear, but that's pretty unlikely for two circuits.
If there is a DB to be fitted next to the panel then you could get a panelboard such as the Schneider powerpact4 which has an extension box available which houses a TPN DB.
Thanks guys, I didn’t think there was another way, but you never know, so I thought I’d ask.
I’m pretty restricted on height, so an extension box wouldn’t work, but I’m not too bad for width. MCCB panel is what I priced for.
Ta
Reply to Distribution in the UK Electrical Forum area at ElectriciansForums.net
We are looking for a distribution board to provide 3 * 160A three-phase feeds, but they are basically redundant supply path options so max total...
Hi all. I have been asked to take over a job an electrician has started, and has moved abroad. The house is a big mansion, with a 3PH supply...
4K
Afternoon All, Just pricing up a job and thought I'd pick your brains. Quick run-down, Block of Flats with an underground car park. In the...
Hello all, I wonder if I can get some opinion on my deliberations on an old TPN installation with numerous 1P sub-boards wired up with 16mm T&E...
