A
Adam W
Is it right/ethical/acceptable to offer advice to DIYers who are out of their depth and doing notifyable work?
There was a thread recently on DIYnot (not that I go there regularly!) about a large number of posts from DIYers asking for advice about jobs which they're apparently just doing the monkey work on, then the qualified sparks will come back (they're usually "on holiday") and do the final connections, test and certify. The general conscensus was that the DIYers were fibbing and there was never any electrician involved.
I'm referring specifically to this post where the OP (new member) begins by saying
"Done a hundred times. I do the work part p leccy signs it off and checks work for me. Just need some help as he's away!! " Then at the end gives the game away by mentioning they have "done the house up" before, referring to everything as 'theirs' (eg my board, my house etc) and saying "I don't really want it to come on with the light only when we have a shower??"... As if a sparky's mate would return to a house they had worked on to have a shower.
As is regularly mentioned this could be described as "a help forum" but surely it was intended more to provide a discussion forum for electricians rather than somewhere DIYers can get free help on work they shouldn't even be doing? After all, you can tell someone how to wire a plug (which wires go where) but that won't guarantee they'll do it properly.
Am I just being paranoid?
How many sparks go around certifying DIYers' work?
Do you?
I'm 100% behind you and there has been many times where we read a post , and you know that these people should not be touching the installation with very little knowledge , but me and a few other forum members have been told off for voiceing the opinion on this,
We are told that if we have no advice to give then we should say nothing( head in the sand mode)
But I'm all for a safe electrics and I don't mind general help to stop someone killing them selves, but think that we should not give out advice on how to wire things up, otherwise we become as bad as B&Q with there helpful diagrams
I'm with you it's a forum for advice between fellow sparks and mates.
One thing I would be worried about is giving a DIYer advice on installation or modification, my thoughts are that if it all went pear shaped and he killed his 5 year old daughter, questions would be asked. Firstly where did you get that advice from, it's from a qualified spark. You could be liable too.
I think you should put a disclaimer on the end of every advice post, but hey I work in industry where H&S has gone mad and we all try to avoid liability.
Much of the advice should just say no you cant do that you need an electrician it's illegal.
it is atricky one though, being able to identify trainees/ adult learners showing an interest and trying to understand from the diy guy.
now simple things like moving a switch or adding a light is one thing and advise can be given but you do get a lot who want to move there own fusebox etc etc and are way over there head
Do you?
Im with you i think there needs to be transparency in our trade, we already get a name for trying to be behind the door with what we do ie people think we over complicate our job to justyfy ripping them off, but i akso think we need to be carefull not to arm half wits to stupid to call out a sparks, with a little information being enough for him to blow his meter off the wall!
I think Sirkits idea of using enough technical terminology to put people off is the way forward !!
Its called Vicarious liability and its a real threat to forums like this
Personally I would never certify someone else’s work.
Regarding the other issue of should be offering advice for complex or notifyable
jobs, I would certainly say we should not.
Question.
If someone’s house burnt down after an electrician on this forum explained how to change a C.U or the like, would the forum be liable in a court?
Ian
Which is why I say that it's better not ot post at all rather than start an argument that gets out of hand where people get upset.
By all means advise them to call a spark for their own safety just dont get personal.
Spot on Lenny, there is no need to have a go at them, they usually just don't understand what's involved, advice should be clear and along the line of you can't do that unless your Part P or notifying LBC in advance. You really need a spark bla bla bla...
We often have maintenance engineers phone us and ask question about faults on our installs and we usually give very basic info followed by you need an engineer do do that.
After all every bit of advice you give somebody to do it them selves is a job less for you. :)
The problem is if you advise someone to call an electrician they often tell you they've already got an electrician coming in to 'check it and sign it off' and they just need a few pointers so they can crack on. If you recommend getting advice from the spark who's putting his name on the cert they'll tell you he's "away".
Whenever someone says that it's always blatently obvious they're not getting a spark in - as everyone has said so far, electricians just don't sign off work for DIYers, but as Lenny says it's best not to come straight out and call someone a liar because they tend to get upset.
Does lying divert liability if something goes wrong? Is there such a crime as 'obtaining DIY advice by deception'?
fraid not
There are books available that are aimed at DIYers doing electrical work.
The authors of those books are actually being paid for their advice, whereas a forum is free of charge.
Its possible that people will try to sue but I cant see that they have a leg to stand on, especially if they were acting on free advice they got off the 'net'.
The requirement for being 'competent' to work on electrical installations is law, and being unaware if this fact is no defence in court.
I read once that a woman tried to sue Google because a walking route planner led her across a busy road, and she got hit by a car.
The court decision was that although Googles information was inaccurate the woman should have also applied common sense.
Its a mad world!
Most of the books carry a disclaimer, stating electrical work should only be carried out be a competent electrician.
It's not really is someone sues you privately, its more if say a child dies then the CPS and police want to make a point they go after the person who gave the advice.
I'm not saying don't give advice I'm just saying be careful and point them towards a spark.
Check my new Signature lmao
