G
guru_bob
Hello, this is my first post so go easy.
I'm not an electrician, but my mate asked me to have a look at the wiring in his kitchen, as I know a bit more about it than him. The kitchen was installed a couple of years ago, and the fitters seem to have made some extensions to the existing ring main.
The picture shows what's there now, hope you can see it okay.
They have run one long spur from one outlet and attached two double and two single sockets to it, which I know is wrong. The last section of cable (from the worktop sockets on the right to the cooker hood socket) is 1.5mm^2 cable (everything else is 2.5mm^2). The cooker hood socket is marked 5A max. The under-cupboard lights are connected using a normal lightswitch.
So what I reckon is:
(1) the spur needs to be connected via an unswitched fused spur unit with 13A fuse
(2) the lights should be fused down, so replace the existing switch with a switched fused spur unit with 5A fuse
(3) the cooker hood socket should maybe be fused down in the same way?
Would that bring it up to scratch, or have I missed things?
Any help or advice gratefully received!
Bob
The picture shows what's there now, hope you can see it okay.They have run one long spur from one outlet and attached two double and two single sockets to it, which I know is wrong. The last section of cable (from the worktop sockets on the right to the cooker hood socket) is 1.5mm^2 cable (everything else is 2.5mm^2). The cooker hood socket is marked 5A max. The under-cupboard lights are connected using a normal lightswitch.
Bob
