Discuss does this count as a Main Linked Switch in a CU? in the UK Electrical Forum area at ElectriciansForums.net
Hi - looking at Table 537.4 in BBB (selection of isolators etc) its probably no surprise that BS4293 devices are not mentioned. I think that series was replaced by BS61008 - and those are ok as an isolator. But then there’s Reg 314.2 so the cup really was half empty :oops: .
Reply to does this count as a Main Linked Switch in a CU? in the UK Electrical Forum area at ElectriciansForums.net
I wondered if it is OK to have 2 x Main Switches in the same consumer unit. One feeding the RCBOs in the House and one feeding the CU in a garage...
Good evening, I wondered how the MCB between RCD and the Main switch is wired while watching this video. Photo attached. I assume a busbar link is...
Hello mates. i have an MK CU to replace. As you may know, the main switch in MKs is on the left hand side. There's no way to replace the...
Can a domestic consumer unit feed another consumer unit, via the Main Switch. Details are: domestic property with 100A single phase supply...
Hello, I need to run a mains spur off the existing ring main in a domestic property. To get the double socket to the correct place I have to drill...
