K
KenWall
Hi I have problem wiring up DOL starter
Circuit trips breaker when try to start
I must be wiring something wrong
Any help would be appreciated
Try referencing against this, out and about ATM so can't get them up side by side to verify myself.
There is also the very real chance you've not set the overload correctly, I'd start with that
I’ll wire it up as per your diagram
I’ll wire it up as per your wiring diagram
The wiring looks ok. When you say it trips the breaker, do you mean the MCB supplying the starter? if so what is the rating of the MCB
KenWall,
freddo,
