Discuss Domestic Help - I’m not an electrician. in the UK Electrical Forum area at ElectriciansForums.net
hi I wonder if anyone can help a lady out!
My fuse board RCD started tripping out every couple of minutes last night. I went through and unplugged everything.. switched every plug switch off!
I think I’ve managed to isolate it to the kitchen Ring main. This is the only one when switched on trips the RCD. Only thing is everything is unplugged and all switches are turned off, why is it still tripping when nothing is on? We currently have no heating, fridge freezer way of cooking etc and I have two small children. Is this going to be a very expensive fix?
Thank you for any help advise.
A fuse board with rcds?
Reply to Domestic Help - I’m not an electrician. in the UK Electrical Forum area at ElectriciansForums.net
Hi, I moved home a few months ago and the electrics RCD keep tripping. Sometimes it will happen every few days and sometimes will be fine for a...
7K
I'm not an electrician. I clean cookers and today arrived to a rangemaster range cooker. Got started, and as part of my routine, I turn on ovens...
Hi all, Gone to look at a intermittent ground floor sockets fault today, the RCBO was tripping at random times with no pattern. Nailed down a...
Having trouble figuring this one out. House was built 5 years ago. Eaton box and breakers. Over the past 3 weeks, the bedroom breaker keeps...
