Discuss Don't you just love builders! in the UK Electrical Forum area at ElectriciansForums.net
Hi all, long time member but 1st time posting in a long while, just thought I'd share this little nasty I came across whilst carrying out a ECIR at a domestic property recently, the family had a small extension built about 20 years ago they reckon and the builder installed this shiny new RCD protected CU to protect the new 16A radial for sockets, a 16A radial for an outside socket and a 6A for the lighting, great I thought as the main board protecting the rest of the house is an old wylex with BS3871 breakers, so I got the feeling things weren't good when on removing the front cover, the whole unit came out, it had been plastered in place to hold it in, no screws holding it in, nada! The unit was clearly broken, top left corner, earth terminal missing and no busbar protection and to top it off, the incoming supply 'tails' were twin 2.5mm off the kitchen ring main!
Needless to say I gave it a C1, anyone got any thoughts to the contrary?
(The board was isolated when pic taken!)
Cheers all
Nice! ?‍♂️
No question that it's a bodge job from start to finish and needs redoing.
Though, just for arguments sake, if the front cover was on, I'd say it would be a C2 rather than a C1.
I guess the 'tails' are effectively on the RFC then? so protected at the other end by 30A fuse, and probably won't be overloaded...
Rare to see builders use decent kit like Hager though!
Nice! ?‍♂️
I decided C1 due to the board not secure and a potential immediate risk of harm if a decorator for instance disturbed it fell away, as usual open to interpreation!
Reply to Don't you just love builders! in the UK Electrical Forum area at ElectriciansForums.net
Doing a lot of EICRs at the moment and have came across what I'm sure is a common enough problem. In an off grid rural cottage I have a TT system...
I'm writing this mainly hoping something occurs to me while writing it! I got called to an occasionally tripping RCD. It's a Hager double height...
  • Locked
5K
Last week I was working in a house changing a socket. When I turned the main switch back on and the MCB on the socket didn't energise. I went and...
