littlespark
Staff member
Supporter
Patron
Aug 12, 2017
14,337
20,736
3,557,381
51
Scottish Borders
My neighbour had a second doorbell chime fitted a while ago, Both chimes are fed from the original transformer in parallel, with another bell wire core between them to ring them both. The bell push is connected to the second chime.
I had a quick look today, and sometimes everything works, other times not.
ie, when button is pushed, both chimes go Ding, release the button, both Dong.
I’m certain it’s been connected up correctly, but will draw a circuit diagram for it if I need to.
When it doesn’t work, you can hear the solenoid buzzing when pressed, and a slight dong when released
My thoughts are, the transformer isn’t powerful enough to operate 2 solenoids at the same time.
Is my initial suspicion correct?
Can you get a wired electronic type sounder that wouldn’t be affected by lack of power?
Ive got a Byron rf doorbell in my own house that gets plugged in, with a battery powered push button. Is there an rf option that takes power from the transformer, and the ability for one bell push to operate two bells?
As an Amazon Associate we earn from qualifying purchases.
Is the push switch new? Might just be crappy contacts on it.
  • Agree
Reactions: James and 123
I have fitted two door bell circuit's off one transformer with no problems.
+1 I'd be looking at the door bell switch. If the transformer wasn't powerful enough I don't think it would be able to work some of the time
littlespark
Staff member
Supporter
Patron
Scottish Borders
Double ding dong doorbell.
littlespark,
