1strangefish
Hi all
First off, Merry Christmas and all that Jazz
I am after some help to speed up the time it takes me to install downlighters.
I use fire rated 12V IP65 downlights in bathrooms. When installing with a pull cord I run the power in to a 5a 4 terminal JB. Then 2 core to pull cord for live/SL. Then run first cable from JB to first tranny
using a choc box (screwfix equivalent) and 3 terminal blocks, i loop in and out then connect the tranny and finally the tranny to the down light, then move on to repeat x number of times. All usually done in loft space.
Completed job yesterday, where I had to measure out and drill the holes, while avoiding joists ETC
also install a showerlight fan using a similar approach to above but including a 3a FCU. Also added two pull cords.
Had some issues wth the joists and the position of the fan which I had to overcome, but ended up being onsite for 8 hours with not much of a break.
Is there a quicker/easier way of doing this as it seems to be taking me for ever.
Any help you guys could offer would be greatly appreciated.
Cheers in advance
Fish
Cheers in advance
Fish
