9regnac
Installing 6 down lights in a kitchen. Property is a bungalow. Would you use fire rated ones or just normal once
Fire rated every time. Should ban non fire rated ones. Must use fire rated where ceiling is plasterboard and in a high risk of fire.
Fire rated downlight are only required to be fitted into a fire rated ceiling. They are not for preventing fire they are for maintaining the integrity of a fire rated ceiling if a fire is present in the room.
Dan is correct, I believe it is to do with zoning & fire compartments, but a single house is one fire compartment, so there is no need to install fire rated downlights within the property, but i may be wrong!! but for the price difference why not fit fire rated anyway. They will help prevent the spead of fire into cavities and lofts, possible saving a house from being totally destroyed.
Standard plasterboard has a fire raring of 30mins I believe so you would have to use fire rated down lights to maintain that 30mins.
Why do we keep having this conversation??? More importantly why keep worrying about fire rated when smoke alarms should be the more obvious concern. I'd rather know a fire was about to start than worry where it will be in thirty minutes.
A non fire rated downlight will maintain the 30 min fire rating of Standard plasterboard.
You are only required to fit fire rated equipment to maintain the flame propagation prevention properties of a fire compartment, which standard ceilings inside a domestic dwelling are not.
I have personal experience of a house fire and I can tell you, the rest of the house and contents will be well trashed before the ceilings start to burn through.
Smoke alarms now fitted throughout!
I use fire rated fittings because they enclose the lamp, stop 'stuff' getting on the lamp and stop dust from falling through.
Couldn't agree more, for the price difference you would be a fool not to. I'd rather have the back of that lamp enclosed in any situation not just for the fire rating properties
Dan, Soulman and Richard are 100% correct. If this is a single dwelling there is no need for fire rated fixings but if this was a set of flats you would need to install them because they are two separate fire compartments from one flat to the next.
If it was a house with stairs, again you dont need fire rated fixings because the stairs link the both floors and its a single dwelling.
As above, for the extra few pence you might as well use rated ones and they feel better made.
I thought if it was a habitable room above fire rated lights were needed, I did always wonder about the stairs though, so comment from Paul does seem to make sense, however I'm sure if there's any rsj's in the ceiling the fire barrier has to be maintained.
Due to dust falling through, insulation finding its way onto the back of the lamp I always fit fire rated downlights
If its a shared house eg student lets, the ceiling, walls, doors and light fittings must be able to withstand 30 mins of fire. Because this is a rented property it goes under house in multiple occupancy (HMO) laws, the fire barriers must be maintained to the 30 min rule regardless of stairs. If it a domestic property for one family only the HMO laws do not apply.
Fire rated every time as Ive come across too many cases of melted transformers/cables etc touching hot lamps, because whoever installed them just shoved everything back through the ceiling hole. Fire integrity is more to do with damage limitation, as the occupants should be well clear if the alarms are working....
