We are having the kitchen refitted and I need new lighting in the kitchen. I intend to use LED lights and currently have GU10 fittings but there are not enough!
I have heard of GU10 fittings with removable bezels that can be removed for decorating (our decorator hates down lighters!). I believe that Aurora have suitable GU10 fire rated fittings but have been unable to confirm with total confidence that these meet my requirements so I am asking for help.
I strongly prefer GU10 LED bulbs rather than integrated LED fittings as there is more choice of beam angle and colour.
I would like to be able to remove the bezel (and if necessary the GU10 bulb) and simply paint over the rest of the fitting without removing it. The decorator would not then complain. Is this how the Aurora fittings work, and are there any alternatives?
The property is a bungalow and the lights will be covered by the fibreglass insulation.
Are you able to give me part numbers so I can be sure of specifying/getting the right fitting. I would want a white (probably gloss) bezel.
Can I get a dimmer that will be capable of dimming 12 LED lights or would I need to divide them into say 8 + 4?
The wiring is easy, the floor joists run in a helpful direction and my draft layout design (using 12 fittings in three rows) misses all of the joists by a sufficient margin. I am intending to get the lights fitted professionally along with the other wiring that will be required in the kitchen. We are in the process of talking to kitchen designers. See diagram - the circles are for a 36 degree beam angle at work surface height.
I also intend to replace the 4 existing fittings that are in the dining end of the kitchen and have LED bulbs already so they match. An electrician removed each of these fittings to change the GU10 sockets which would only take very long GU10 LED bulbs and this badly chipped the plaster around the fittings. I am trying to avoid this for the future.
I think this is the product you are referring to;
Universal™ Fixed Fire Rated Downlight - http://auroralighting.com/gb/ProductDetail/AU-UNIF861
Personally I would use an integrated type. I know some people like lamps like the Phillips Hue etc, but they don't cut it for me. And as for changing the lamps when new technology comes along, that ain't doing a lot for the Planet, is it. I have some of the original LED GU10's, about 7 years old, still working. Why throw them out?
Given its a bungalow, surely there is some sort of access or potential access to roofspace above the new works, Would advise removing the insulation around the new lights. It minimises potential risk later down the road.
looking at the amount of lights and the spacing., is this kitchen going to be used as a kitchen or a cannabis farm?
Great Missenden
Website
Http://www.soroban.co.uk
Other
If other, please explain
Electrical Engineering degree, professionally computer designer, and recently network and system security architect (55 years). Now recently retired but still interested in all electrical and electronic matters. Have contributed answers to questions with and electronic video or networking slant
Business Name
Was Soroban Systems Ltd (closed last year)
Downlighters required with removable bezel
jcs8215248,
Electrical2Go,
