R
Rammie
Hi
Did a silly thing today and cut one of the holes slightly too big and thus the fitting will not hold correctly- Doh! :o
Anybody done anything remotely as daft and found a solution that ensures the light stays in place?!
Thanks all...
Rammie
The steepest learning curve of my life!
Yeah I've done it, you never do it again I can assure of that.
I pushed my downlight to one side and using a cut of the circle I'd cut out kind of wedged it in place. Then out came the magic filler, you'd never have known after it had been painted in.
The other option is to ease a piece of batten or something (preferabley non flammable) for a fixing up to one side of your downlight and screw the section of the plaster circle into this then patch over. Obvious concern though is wood right next to the fitting.
Quite hard to explain, especially after a few tins, sure it happens all the time though.
loads of easyfill slapped around the hole ..untill its almost covered uo...let it dry....gently drill your new hole in the same place with a new SHARP holesaw....gently shaving off the excess dried filler. sand to a smooth finish if required. serve with salad garnish. oh yes!
it must be proper EASYFILL ( get small bag from brewers ) you will never use any other filler again after that stuff its magic
