Discuss Driveway audible alert ideas in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
Has anyone got any recommendations for a wired driveway audible alert? A friend has a large drive and wants a PIR to turn brick lights on upon vehicles coming up the drive and also an audible alert at the same time.
I doubt there is a device that does both so probably a separate PIR and then something to alert them of a vehicle coming up the drive.
Any suggestions?
There used to be a simple lighting system with just this setup, a simple slider selected what function you wanted, lights, lights and beeper etc. the PIRs were 12V. Not sure if they are still made though. The unit fitted a standard double box.
I
That would be ideal
I was in a house last week with that system. It’s a 4 zone fits a 2G box and each zone has ability to turn lights on and buzz inside separately or together
Can’t recall brand.
So with these systems, they can switch a lighting load via a sensor and offer an audible signal within the property?
There is a controller which would go in the house, this has a buzzer in it which sounds every time a sensor detects movement.
The sapphire is single zone an dthe merald is two zone.
The PIRs are extra low voltage and usually wired in alarm cable, they can be split across three circuits in each zone (you can have multiple PIRs on each circuit)
Lux levels, walk test and number of detections required to activate the output of a zone are set from the controller.
Each zone has a relay output which I think is rated for 3kW
There is also a connection to link it to a burglar alarm to bring security lights on whem the alarm is triggered.
Done this recently with gate sensors, relay, psu and RF mains link. Other end of rf mains link was then plugged in the house 300 meters with another PSU, relay and piezo buzzer installed in an adaptable box. Gate sensors was installed at a height where foxes etc wouldn’t be detected but a human or vehicle would.
Reply to Driveway audible alert ideas in the UK Electrical Forum area at ElectriciansForums.net
Hi I'm having a full house rewire. I want to have mains smoke alarms, heat alarms, carbon alarm next to boiler, internet connectivity to notify...
5K
Hello everybody from Germany! I'm feeling sick with this car, it won't start, just very rarely...please help me out. Car: Opel Corsa C 1.2 2003...
This isn't really an electrical issue as such but I know you guys are pretty tech savvy and familiar with all the latest and greatest...
Hi, First of all I must explain why my posting came to be on this site, I was looking on the internet for a forum that could help with a project...
Hi. I'm an I.T.. engineer with some outdated electrical experience. I qualified C&G 2330 17th edition about 15 years ago, but my only experience...
