Discuss dumb question of the week in the UK Electrical Forum area at ElectriciansForums.net
During the summer I went to a call out, the woman said that the 'switch thing on the board has just gone floppy and won't stay up anymore'.
When I got there, she had stuck it up with tape. I could see a gap between it and it's neighbouring Cbs. I took the tape off, it tripped with a flash straight away.
found a few seconds later that it was a wylex breaker (I think), fitted to a Hager board very loosely. It had overheated so much it had welled right up andwas a nice shade of brown blob at the bottom!!
ive seen contactors wedged in with plastic strips to keep the contacts closed. and steel wire bridged across overloads in a radio station
had a good time reaming the twits for doing that
Yes yes yes, contactors forced in with zip ties, pen tips, push buttons forced in with hair clips.
I was carrying out an inspection on an installation following an 'electrician' who suffered an electric shock after he cut through a live SWA cable by mistake. I was brought in to offer an independent review of the install. Said electrician came up to me and said the MCB 'didn't work properly?' And could I test the MCB by putting a fault through it! I suggested he tried plumbing instead...:/
My favourite is an 'added' shower in a small house with a 4 way 3036 board. Clearly didn't know what O what to do as no space! No space! So just shoved the radial into the main switch.
I guess if there was a fault you ran downstairs through the lounge, got the steps out, took the cover off the cupboard and switched the house off.
A least it was protected by the DNO fuse LOL
Doing some Portable Appliance testing on an Army base along while back, found a live .22 cartridge as a fuse lol
Site where I work used to be a muntions factory during the war, recently there was enabling work going on for a new plant to be built one of the labourers worked into the office with an old .303 bullet, he asked what do I do with this.
so what if it was on a production line then?...or say a process that couldn`t just be shut down....
what do you do then when the contactor starts arsin about?
Reply to dumb question of the week in the UK Electrical Forum area at ElectriciansForums.net
Having trouble figuring this one out. House was built 5 years ago. Eaton box and breakers. Over the past 3 weeks, the bedroom breaker keeps...
My friend just moved into a new build flat and its for a disabled person with a hydraulic lift to go to the upper floor. There was/is a leak...
This question has probably been asked several time but things change. The house I'm living in now was built in the 1960's and has a ring main...
Hi all, it's been a while since I've been on, apologies. I am debating whether I need to replace the bonding to the gas meter. The meter is...
I will describe my problem in as much detail so you guys might be able to answer my question. I am never home, my Electric bill is $ 28 to $30 a...
