Streetwear87
We have measured 50mA earth leakage from an oven.but during we touch the metal surface we do not receive shock :D how?
That's what should happen
An electric shock shouldn't happen regardless of leakage when all is well
What do you mean exactly?i am confused.
Also the oven is RCD protected and it does not operate.RCD is tested an work well.
How are you measuring the leakage and what with
Between lines and neutral.its 3 phase.we have measured with earth leakage clamp meter.the best think is,we did with 2 differen clamp meter but we obtained the same results.
I presume it's a dedicated rcd that's not being blinded by another appliance fault ?
I dunno , someone else smarter will probably figure it out
