J
Jackflash
Hi,
I'm working on a property that has plastic water pipe installation with no gas but has a steel solar / immersion heater water tank with copper pipes to solar vacuum tubes on roof and copper pipes to wood burner. Does any part of this need bonding?
probably not. acid test is to IR test at 500V from the suspect pipes to the MET. if >22kohms, then don't bond.
but surely the main earth needs to be connected to the MET, otherwise the MET is not earthed.
yep.and i forgot to mention disconnecting MET from installation, so we both got to stand in the corner till playtime.
