10.5 Edge-triggered Latches: Flip-Flops - https://www.technocrazed.com/10-5-edge-triggered-latches-flip-flops
Further to previous advice:
If what is attached does not make sense to you then come back. To provide some points of interest and topics to research an electronics engineer would have the following questions:
1. What is the specification of the input pulse you which to detect and then stretch for a pre-determined period. ie: Is it a standard two-state logic signal or some other two state signal? How noisy is it? Is there a minimum time period of the input pulse which has to be exceeded before a stretched pulse is output? What is the nature of the input pulse - periodic or random? What frequency?
2. Do you want to trigger the stretched pulse when the input pulse transitions low to high - leading edge - or when it transitions high to low - trailing edge?
3. Is the circuit one-shot and then inhibit? ie once a trigger occurs and there is one output pulse and then no further input pulse transitions will cause a further stretched output pulse until a reset signal is applied?
4. Further to 3 above - Is the circuit one-shot and then timed inhibit?
5. Do you want a controlled reset during the period of the stretched pulse being high?
6. Is the logic circuitry part of combinational or sequential logic circuitry? Is the logic circuitry Synchronous/Clocked?
7. When power is first applied what do you want the output state to be?
Anyway - by way of practical help and with simplicity (always a good thing) in mind - I have two 74LS122 retriggerable one shot and clear ics gathering dust in my shed. You can have them free if you want. Send me a private message with your address and I will put them in the post. The deal is that if you do use them you report back your success with pictures. I will add in some 555s too.
https://www.ti.com/lit/ds/symlink/sn74ls122.pdf?ts=1636101701394&ref_url=https%3A%2F%2Fwww.ti.com%2Fproduct%2FSN74LS122
