Discuss Eaton BR4040L convertible to Main Breaker? in the UK Electrical Forum area at ElectriciansForums.net
Zenney
Hi All,
I have a BR404L box and it looks like I can convert it to a Main breaker by changing the cover and adding a 200AMP main breaker where the Lugs are. Is this possible and or recommended?
From what I can see you would need to swap the two main leads, is that correct?
Thanks in advance
Reply to Eaton BR4040L convertible to Main Breaker? in the UK Electrical Forum area at ElectriciansForums.net
I recently purchased a rural property in Arizona. The property receives power from APS, the local electric utility. Power arrives from the...
I am building a duplex. The service enters the house through the wall of one of the units, where the main panels for both units are located. Then...
Mobile home outdoor power supply is a pedestal that power to the mobile home plugs in much like an RV. The main power supply into the mobile home...
I’m planning a 240V welder circuit in a detached garage with a 100A sub panel. For the 160A or 180A output welders I’m looking at, the conductor...
