Discuss EICR help in the UK Electrical Forum area at ElectriciansForums.net
Hi looking for some advice, basically have an upfront 100mA RCD at 1 DB that feeds another DB with no RCD just MCBs in 2nd DB, now on schedule of tests it says over current which at 2nd DB which will be my 100mA RCD and Associated RCD but where Operating current for each circuit is would you put the 100mA in there too?
An RCCB is not an overcurrent protective device. It offers residual current protection (earth leakage) but does not protect against overcurrent. The type of RCD which has integral overcurrent protection is an RCBO.
What Risteard said, what's with this 5 words message?
your overcurrent protection for DB2 is the 80A MCB in DB1. for each circuit in DB2, the MCB for the circuit is the OCPD for that circuit alone. bet yo have a few C2's for no 30mA RCD/s
Yes then the associated RCD would be the 100mA RCD, what I mean is none of the circuits have RCD so could you put the 100mA in Operating mA for all circuits? It’s failed anyway but person at work says yes but I’m not sure as in a way they still are governed by that upfront RCD
see what you mean. enter the 100mA RCD as 100mA and the time/s in the appropriate column.
Reply to EICR help in the UK Electrical Forum area at ElectriciansForums.net
I was wondering if someone might be able to help either confirm or change my understanding on the use of S-Type RCDs. I believe that they can be...
Hi guys, could someone help with the following please? The scenario is: Domestic property supplied via three phase (with a 3P main DB, NO SPD)...
Trying to organise a CU replacement at home. It's a 1930s property. It's got a 10way CU but with no RCD protection. Was after a larger unit with...
4K
Hi, I need an EICR done on a house I rent out in Reading, 4-bed detached built in early 1980s. But I'm a bit nervous about how to avoid cowboys...
Hello! I've been racking my brain this evening about some RCD selections. I've been doing some work for a solar installer, and they've asked me...
