C
Corky1970
Does that thick black cable have a plug attached to it the goes into the external socket, if so its technically an extension lead and does not require a test certificate.
Yes that double socket was installed when the house was first rewired and as far as I am aware I think you are correct re: the power going through the switch and back to the socket.Just to make it clear, the double socket was existing. Power then goes through the switch fuse to the left, goes back into the socket box and exits onto the black armoured cable.
Ye it will need certification, I would say a full EICR done on the property to ensure no damage either to the installation during the works.Hi - I had a shed built at the end of my garden mainly for storage and to house my dryer for use in winter months. The electrician installed some lights and two sets of double sockets. The electricity supply is connected to the main house supply and has an isolator switch inside the shed door. I have an electric certificate for the house - the work which he also completed in 2019. Do I need a separate certificate for the installation of the supply in the shed or is it covered by the house certificate as it is connected to it to it?
Really? For a 2 year old house where the only additions have been this armoured out to the shed?Ye it will need certification, I would say a full EICR done on the property to ensure no damage either to the installation during the works.
Disagree there mate - it looks like a FCU been added to a ring final circuit. MWC and run!Ye it will need certification, I would say a full EICR done on the property to ensure no damage either to the installation during the works.
Agree as part of that it should be checked exactly how it's
