dannyc
Any help appreciated people looking at some electric gates tomorrow that have stopped working after a power cut. Open via an intercom or did should I say, mechanically sound, sensors new 3 months ago and nothing blocking them. I dont really know where to start never worked on gates before and was looking for someone to point me in basic direction. Can get details of gate tomorrow and will post more info but a general starting point would be great. Cheers
Check that the fuse hasn't blown in the gate unit (if it has one), came across this with one of my customers. Power cut then gates no longer worked. Other than that check the obvious, has gate got power, does relay click when intercom sends signal to gates to open etc
High tower I did but he tracked me down on foot! Ur not the only person to suggest that which makes me worry and why I put the post on!
just don't give a price. tell client it's £XX per hour + parts.
If there is power going to the main board just try re programming them,sometimes they loose there way after a power cut.
a phone call to the manufacturers tech. dept. when you are on site is a good start.
Went to see today found a loose wire and re-connected so sensor working again but key fob is not. Was told another spark went to look and claimed a whole new gate and system was needed. Sabotage?
keyfob might need a new battery.
When fob is pressed against sensor lights come on ticking in control box all seems fine but gates wont open with it
